TPMS Setting on 03 Exped
Old Nov 25, 2006 | 01:16 PM
LBG's Avatar
LBG
Lightbulb TPMS Setting on 03 Exped
I am new to this site and just put a new set of Terra Trac A/T tires on the truck and they are great. The manufacturer says to run them at 50PSI (LT Tire), dealer says to run at 35PSI. Does anyone know if the TPMS can be reset to a higher PSI? If I run at 50PSI tire monitor dispays "check tire pressure"
Old Nov 25, 2006 | 01:39 PM
aagitch's Avatar
aagitch
You should have the tire pressure set at what the manufacturer of the vehicle recommends not the tire manufacturer.
Old Nov 25, 2006 | 01:52 PM
LBG's Avatar
LBG
That's what I have done, TPMS works fine after dealer reset them all with tires at 35PSI. I hope the LT tire will be ok, went from the conticrap "P" as OEm to the Hercules. Awesome tread pattern and nice and quite on highway.
Old Nov 25, 2006 | 02:04 PM
HomerWinzlow's Avatar
HomerWinzlow
Does the manufacturer of the tire recommend 50 or is that the MAX inflation for the tire?
Old Nov 27, 2006 | 07:22 AM
LBG's Avatar
LBG
Max is 80PSI, manufacturer recommends 50 PSI, FORD says 35 PSI
