Power Stop Rotors
Old Nov 25, 2006 | 10:19 AM
sgrol's Avatar
sgrol
Power Stop Rotors
Just replaced my front brakes with Power Slot cryo slotted rotors and Hawk pads. Now I need to replace rear brakes (warped) and don't want to spend the same $$ for the Power slots. Has anyone ever tried the Power Stop rotors? I figured the fronts do most of the work so I wouldn't need real expensive brakes on rear. Somebody straighten me out if that's not correct.
Old Nov 25, 2006 | 11:45 AM
cnd999's Avatar
cnd999
I don`t see why you wouldn`t be ok with different rotors out back.Cannot comment on the powerstops tho.
Old Nov 26, 2006 | 09:20 AM
Mark at DPPI's Avatar
Mark at DPPI
sgrol,
If you're going to do that you might as well get stock rotors as the result will be the same and save you even more money!!
Mark @ DPPI
