I'm hacing trouble finding the part number for the plastic handle that releases the second row passenger seat to allow it to tilt forward.
Anyone have this?
Thanks
Anyone have this?
Thanks
weedhopper.....you're talking about the second row captain's chair I take it???? If so, it's off to the junkyard for you....I checked with Ford here in Houston, and that handle (or the whole assembly) is not available anymore.....
yep thats the one, hmm wonder if they will sell the just the handle
or if its gonna be a whole seat?
which reminds me the only problem I've seen on this machine is the airbag light
flashes 2 times then pause, it continues this cycle as long as the switch is on.
sorry bought the questions, i've been stuck in chevy hell for 3 years.
32 Driver Side Air Bag Circuit High Resistance or Open
probably failed clockspring spiral wound circuit assembly under steering wheel....
does cruise and horn work....these also pass thru same unit
several FTE Ford dealer site sponsors carry in stock and discount the price from normal full Ford retail....
see Ford Service cd, Chiltons or Haynes for proper SAFE replacement method
clockspring failure is common in Aero's especially in urban driving
extensive troubleshooting is covered in Service cd....but most of it involves accessing clockspring so may as well just order replacement and put in instead of taking apart twice
