Help
Old Nov 25, 2006 | 12:36 AM
dbaker1097's Avatar
dbaker1097
Help
Can any body tell me what the EBPV seal is and also how hard is it to fix. What about the turbo pedstal o-rings, is this something I need to take in to the shop or do it my self. I have an oil leak on the top back side of the motor. There is oil standing on the intake behind the fuel filter housing and also running down the back of the motor. Thanks for all the help in advance.
Old Nov 25, 2006 | 12:43 AM
Tenn01PSD350's Avatar
Tenn01PSD350
That valley oil problem generally tends to go back. I don't doubt it is leaking down the pedestal but you may have something else going on. Time for some simple green and a hose. Clean it all out and blow it dry in order to observe where it is coming from. Then post results. The fan tends to blow it to the rear.
Old Nov 25, 2006 | 05:55 AM
ponch37300's Avatar
ponch37300
If it is the ebpv seal there is a rebuilt kit for it http://www.dieselsite.com/index.asp?...ROD&ProdID=314If it is the o-rings they are found at a number of site sponsors.
