Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
ABS Warning Light on and more????
Old Nov 24, 2006 | 07:57 PM
ggadwa's Avatar
ggadwa
My 2006 Escape XLT just started a very undesirable Indication on the DASH....ABS light on constantly when vehicle is running AND the 4WD light comes on about every three or four minutes and flashes 5 or 6 times.....
I'm sure this is NOT a GOOD thing!!!!
I tried two different times disconnecting the battery for 30 minutes plus.....Still same indication on the dash....
ANY IDEAS....is anything wrong???? How do I get the warning lights OFF????
Vehicle seems fine.....of course its hard to tell with the electronic AWD.
I live 140 miles from the nearest FORD dealer....should I be seeking FORD Help or?????
GARY
Stanley, IDAHO
Old Nov 25, 2006 | 07:27 PM
MazdaRangerGuyInSTL's Avatar
MazdaRangerGuyInSTL
I don't think there's a whole heck of a lot you can do yourself unless you have the ability to pull codes from the ABS system.
Plus the vehicle may still be under warranty.
Old Nov 26, 2006 | 08:12 AM
5_labsownus's Avatar
5_labsownus
Without the codes it would be hard to say. But in other Fords it is most common that a wheel sensor is bad and will give you an ABS light. With the Escapes power train configuration it could very well give you a 4x4 light to indicate the failure.
Old Aug 25, 2008 | 10:16 PM
zempman's Avatar
zempman
I've got the exact same problem as Ggadwa with my 2005 Escape. Has anyone come up with a difinitive diagnosis and /or solution? Any help is appreciated!
Old Aug 26, 2008 | 07:12 AM
DoctorCAD's Avatar
DoctorCAD
Broken ABS tone ring. Causes the ABS light and the AWD uses the same ring to detect wheel slippage.
Pretty common on Escapes, well, maybe not common, but common enough that I have read about it on several message boards.
Old Sep 16, 2008 | 07:32 PM
KawiG5's Avatar
KawiG5
Click on the link below for info. pertaining to the ABS on Escapes.
https://www.ford-trucks.com/forums/7...ml#post6554335
ggadwa
Jan 5, 2013 10:56 AM
ggadwa
Dec 7, 2012 09:28 AM
ggadwa
Jan 18, 2011 03:24 PM
sierraben
Jun 7, 2007 04:18 PM
mypa'struck
Aug 26, 2003 10:32 AM
