headlights
Old Nov 24, 2006 | 07:21 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question headlights
The headlights of the F250 (1996) are the same for diesels that for gassers and for the F150 gassers?. the question is because I live in Mexico and I can buy the headlights for F150 gassers. I dont like the yellow color of the olds ones.
Anybody has used the xenon lamps GE 9007 HO (high output) in his truck, are there any troubles, or you have to add a relay or something else? And really the ligths are better? I just bougth a pair of that lamps and I m thinking to change them for the stock (9007 halogen)
Thanks in advance.
Old Nov 24, 2006 | 10:20 PM
sneal's Avatar
sneal
Too old for this
The gassers are the same f150, 250, 350 just not the E version. When going to the HO lights upgrade your wiring harness and put an Aux relay in. For details do a search on google for a heavy duty harness and you should get the ideal. If not repost and I can post exact pics and diagrams. You might look under my name for all my post and see if there is enough information there, someone had this question a couple weeks ago.
Old Nov 27, 2006 | 02:33 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thanks saneal, im going to look for the harness and relay. I dont know why I cant see your post throught your name.
Old Nov 27, 2006 | 09:08 PM
sneal's Avatar
sneal
Too old for this
Try this
https://www.ford-trucks.com/lc/lc.ph...sdetail%2F1983
https://www.ford-trucks.com/forums/5...eadlights.html
If these don't work look for the post called clear headlights, I will revive it.
