problem with SCMT
Old Nov 24, 2006 | 01:30 PM
ktplotts's Avatar
ktplotts
problem with SCMT
I tried to re-tune my truck today, and keep getting a message that the vbatt is too low for programming, error code g-33. The truck batteries seem to be fine, the truck starts just fine and powers everything. What could be the problem?
Old Nov 24, 2006 | 11:05 PM
BowTieHatr's Avatar
BowTieHatr
take a test light and check to see if you have power on pin 16 of the dlc. it should be the bottom right pin. it should be the only pin with power. if no power, then check your fuses.
Old Nov 25, 2006 | 01:54 AM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Make sure that ANYTHING that could drain amperage from the system is off during the download- headlights, blower motor, any accessories, ect. Also make sure the truck is hot- if it is cold, it is trying to fight the GPCM for power to the glow plugs.
Old Nov 25, 2006 | 03:36 AM
ktplotts's Avatar
ktplotts
Thanks for the help. I think you might of hit it right on the head with the GPCM, since it did it a has been ocurring more often now. Even with all the accesories(radio and air) off, it still wouldn't do it when the truck was cold. I drove my truck about 10 miles and stopped and tried again and it worked fine.
Thanks for the help,
-Kevin
Old Nov 25, 2006 | 03:51 AM
SpartanDieselTech
Former Vendor
The GPCM draws 20 amps PER plug....thats alot of current load, and can have a quite negative effect on system voltage when the batteries are cold also. Glad that it worked for you.
