abs line
Old Nov 24, 2006 | 10:22 AM
tfdcapt's Avatar
tfdcapt
abs line
I have a 2001 ford F-250 PSD and the right abs wire has been pulled out from the connector. My ABS light is on and I am sure that this wire is the cause. This wire is directly attached to the hub. Is there a kit to replace this wire without replacing the hub itself. If not would it hurt to do away with the connector and hard wire the line together. Any information would be appreciated.
Old Nov 24, 2006 | 11:12 AM
kennedyford's Avatar
kennedyford
Makes it hard to do brake work if you hard wire it. If there is enouph wire left and the connector is trashed just place a connector there and get a new on later.
Old Nov 24, 2006 | 11:27 AM
Kwikkordead's Avatar
Kwikkordead
The front speed sensor is removeable from the hub.
You don't specify if you have a 2 or a 4wd truck, the price is different.
Old Nov 24, 2006 | 04:29 PM
tfdcapt's Avatar
tfdcapt
this is a 4wd truck and the wire that is broke is the one that goes into the hub and after talking with some other owners I am pretty sure this is the ABS wire. It connects to a wire that is on the backside of the wheelwell. I don't know if it come out of the hub so that it can be replaced or not.
