Sponsored by: Real Truck
Auto door lock not working
Old Nov 24, 2006 | 08:50 AM
Jay Bundick's Avatar
Jay Bundick
When pressing the auto door lock fob, pass door locks but driver's door does not lock. Same when trying to unlock doors with remote fob, driver's door does not operate. Any ideas to correct problem?
Old Nov 24, 2006 | 11:34 AM
bronco521's Avatar
bronco521
could be the actuator in the door went bad/froze up.could take the door panel off and see if the actuator will move .if it does see if it has power when switch is pressed.if it doesn't move may need a new one or could spray some penetrating oil on it and work it up and down.
Old Nov 26, 2006 | 08:53 AM
Trouble1263's Avatar
Trouble1263
Does this also happen when using the door panel switch?
Old Nov 26, 2006 | 11:25 AM
heidiandmax's Avatar
heidiandmax
Does it look like the wants to move?But doesnt.It is a common problem with the locks.It isnt the switch,it is the unit that moves the lock itself.Someone here did a nice writeup on this subject and a DYI fix to correct it.Will try to find it........
Old Nov 26, 2006 | 12:12 PM
heidiandmax
No sweat....here it is;
https://www.ford-trucks.com/forums/4...cks-fixed.html
Hope it helps
