Sponsored by: Real Truck
40mph vibration
Old Nov 23, 2006 | 08:44 PM
chopper_53e's Avatar
chopper_53e
40mph vibration
I have a 2000 F250 SD 4x4, with a vibration at 40mph(+/- 2mph). I've balanced the tires twice, and it still does it. Has anyone else had a problem like this, or have any idea what it might be?
Old Nov 23, 2006 | 09:05 PM
Wingedpig's Avatar
Wingedpig
Are you running the Cont. tires?
Old Nov 23, 2006 | 09:06 PM
chopper_53e
The tires are Michelin
Old Nov 23, 2006 | 09:55 PM
darrin1999's Avatar
darrin1999
is it a side-side vibration or up and down? if its side to side its probably tie rods... if its up and down you may have warped your rotors since you said your tires had been balanced twice
Old Nov 23, 2006 | 10:18 PM
chopper_53e
It's not bad enough to tell which way it's moving. It's just a nuisance. I just replaced the rear rotors because one was warped from a stuck caliper. No change after that. I can't feel any pulsing in the pedal, to suspect warped front rotors.
Old Nov 23, 2006 | 10:30 PM
darrin1999's Avatar
darrin1999
id definitely check on the tie rods though... also does it only do it under load or just at 40 going either way
Old Nov 24, 2006 | 12:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
When do you feel the vibration? Only when you apply the brake? Or at certain speeds?
Old Nov 24, 2006 | 01:07 AM
75F350's Avatar
75F350
Having a truck with that many years could mean that any ball joint, or bearing up front could be worn, a hub is stuck, or has not dis-engaged, or, may not even be from the front of the truck. That slip joint on the rear shaft that never gets any attention could be telling you, that it now needs some. Even the carrier bearing could use a little attention, even any of the u-joints could be crying for a little help. Isolating the problem, and determining exactly where the problem is originating from would help. (IE, front of the truck, or rear?) Does the steering wheel shake, is it under acceleration, deceleration, coast, braking...........?
Really sounds like a balance problem somewhere, now you just have to figure out which of the items in the truck that spins around is no longer the way it should be.
Old Nov 24, 2006 | 01:30 AM
chris60's Avatar
chris60
Hi , check out my post on the V10 forum, u-joints and the fix, it may help . That vibration at 40mph was my issue, and it was a u joint.
Old Nov 24, 2006 | 03:07 PM
chopper_53e
The steering wheel doesn't shake, and it does it at 40 mph no matter if I'm braking, accelerating, coasting, or whatever. I suspected the driveshaft, and checked it, thinking maybe one of the balance weights got knocked off, or a u-joint was bad, but I completely forgot about the carrier bearing, and slip joint. I'll check those this weekend.
