feeding the carb
Old Nov 23, 2006 | 08:11 PM
lilman320's Avatar
lilman320
feeding the carb
Ok, i got a new fuel pump for my 79 f250 w/400 but in the process of puttin it in, bent the steel line heading to the carb...now i hate steel line and was thinking of trying a ss braided hose the whole way with a fuel filter in between....the carb wont be a problem becuz the line will just slip over the inlet but the fuel pump on the other hand might be interesting because of the threaded outlet my ? is what type of adapters ect... will i be needing for this adventure the i plan on running -6 AN line which is like 3/8 in line, any help would be appreciated.
Old Nov 24, 2006 | 11:36 PM
LxMan1's Avatar
LxMan1
The pump is set up for a flared fitting, I have seen short flared lines set up for clamp on fuel lines.
