fuel filters
Old Nov 23, 2006 | 09:32 AM
beemr's Avatar
beemr
fuel filters
Where is a good place to get fuel filters today (Thanksgiving)?
Does Walmart carry them?
Old Nov 23, 2006 | 09:43 AM
beemr's Avatar
beemr
I have a full tank of fuel.
How long (much) will it take when I remove the drain plug from the HFCM before I can remove the main filter?
Old Nov 23, 2006 | 10:15 AM
tvsjr's Avatar
tvsjr
Today? That may be a little rough.
I get fuel filters from my International dealer. Since the trucks don't stop moving on Thanksgiving, there's a fairly good chance that the dealers are still open. You require part# 1847170C92.
I don't believe Walmart carries the fuel filters. If they do, they are more than likely cheap FRAMs which lack the Aquabloc media and thus are NOT recommended for our 6.0s.
Personally, I've never had a problem draining the HFCM, even with a full tank. Pull the plug, let it drain until the flow stops (30sec-1min, usually), then proceed with the fuel filter change.
Old Nov 24, 2006 | 08:24 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Try local Int'l dealer or you may just have to wait.... sorry.
DO not use WIX as not OEM spec'd.
Walmart does NOT carry the fuel filters for the 6.0L motor.
Old Nov 24, 2006 | 08:42 AM
Pickupman2004's Avatar
Pickupman2004
I order all my filters from National Fleet Parts. If your order is big enough, you get free shipping. If I had to buy one around town, I have only found them at the Ford dealer......for some reason, I still don't see them much at any other place.
Also, I have never had a problem draining my HFCM with a full tank. I believe you just need to make sure the key is not in the ignition switch in the on position.
Old Nov 24, 2006 | 09:21 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
PART NUMBER
3C3Z9N184CA LIST $70.97 FTE $51.10
I'll sell you one! you just won't get it today :-(
Ed
