You may not need a plug, but a new copper washer. Mine didn't have one so I went to the Stealer and got knocked out of my boots when the guy told me the price. I think it was like five bucks for a dang washer. But he was cool and let me trace it out on a piece of paper. I then went to Advanced Auto Parts and bought 5 of them for a couple bucks. My plug would leak also, then I read on here about the washer. No leak since.
any 1/2" or 14mm copper washer should fix you right up
Austin
Yes, I use a 14x20x1.5 mm copper washer. New one every time. Never leaks.
I've done oil drains on a customer's VW TDI that had a Fumoto. It seems a convenient way to do things if you don't mind the wait. It's a pretty small stream that comes down. I could go eat dinner while waiting for 15 quarts to drain!
Hmmmm, re-thinking that whole Fumoto deal now. I don't want to wait forever and a day for the oil to drain. Maybe I will scratch that from the list.
I changed my oil today, and it took about 12 minutes to drain the 14 Qts of hot oil using the Fumoto oil drain plug, About the same amount of time it took to precharge the new oil filter with oil, and no leaks. I think it's worth the money and make changing oil a little easy er.
