I would like to change out my alternator on my '87 F150 out to a higher amp alternator. I have a lot of off-road lights, as well as a winch system that is going on sometime in the near future. Right now, with just my stereo, the headlights dim everyonce in awhile, and when I go through a puddle while mudding, the amps drop (im guessing until the water spins out). It is a serpentine belt system, and I think that it puts out 60-70 amps, but I don't know.
To handle the new load, I was thinking of putting on an alternator from a '94 Crown Victoria that puts out 100-110 amps. They're both internally regulated, so I didn't see a problem. However, the guy at the parts store said that if I did that, I would be running a huge risk of frying my electronics, mainly, the EFI computer. He said that because of the difference in charging power, I would overload the system (but as long as it's regulated it's ok right?).
So my question is, is he right? I've seen some people do these kinds of swaps, and I know that companies sell high-amp alternators, so what gives? Thanks for all the help
Will it bolt up? I do not think it would, try one from a 1992 E150 5.0 95 AMP.
He is wrong, the EFI computer (EEC) does not know anything about the charging power. (for lack of a better term)
You would not overload anything.
No he is not.
You will have to run a higher gauge wire from the alternator to the starter solenoid, about an 8 GA in place of your 10 GA wire. Also you will need a 12 GA fuse link in it.
Alternator only puts out as many amps as needed, up to its max capability. The max capacity is also dependant on alternator speed. Guy at the parts house doesn't fully understand the system. There are some really sharp experienced guys at parts houses, but many are not. Those jim dandy cumpertized alternator testers are not real good either. Had Auto Zone and Advance test my junkyard 3G before I installed it. No Good, according to both. Took it to an old time alternator shop with a crude set up to drive the alternator. They said it is good. Put it in a few months ago and it is fine.
Do a Google search for a 2g to 3g upgrade. Lots of info with step by step instructions, and pictures. Nice thing about the upgrade is the 3g can produce as many amps at idle, as the 2g at full speed.
If lights dim after running thru water, it is probably cause the belt is wet and slipping.
Good luck Frank
yeah I thought that he was sketchy, as i had never seen him before. i didnt think thait would hurt anything, or they wouldnt sell higher-amp alts, in the aftermarket.
Thanks for the help,
On second note, the lights don't only dim when going through water, but also when my stereo is up loud and all the lights are on.
Your lights dim because your system is taking all the juice. That is, if you have a full setup-amps, subs, all that jazz. My '94 has a good alternator, but if I turn up the bass and the volume, I can still make the lightsdrop a little.
yeah i figured on that, but it also happens when i am driving at night, and even when i turn the heater fan on, it dims quite a bit, so i cant put the heater on high, so im just trying to offer a little more juice to take so that during a heavy battery load, everything will still be peachy keen
go to www.fordfuelinjection.com click on products. site has 3g alts of various outputs, and also pre made wiring harness's and the fuseable link that is important when running any larger then 100amp alt. I run a 95amp currently and wouldnt feel good having lights and good stereo running off of it. 130-160amp is the next upgrade so i can run all of those things and a winch.
