Reverse light adjustment
Old Nov 22, 2006 | 11:04 PM
GreenMachine'77's Avatar
GreenMachine'77
I have a 1977 f100 ranger, and the reverse light does not come on when it is all the way in reverse. It comes on when in between park and reverse, but then turns off when fully in reverse, so i am assuming it is an adjustment issue. How do i adjust the switch??
thanks
Old Nov 22, 2006 | 11:40 PM
Mil1ion's Avatar
Mil1ion
This is a bottom looking up view.
You need to put trans in neutral...
Undo shifter arm.
go to column and loosen mounting screws on NSS and line up holes by inserting drill bit in hole.
Tighten everything up...remove drill bit ....
Test BU lights and Neutral /park position start
twisstedex
Feb 23, 2018 08:00 PM
grande1972
1983 - 2012 Ranger & B-Series
Mar 17, 2013 06:21 AM
cray0971
Aug 25, 2011 08:46 AM
mfp4073
Jun 2, 2010 05:35 PM
ATC_250SX
Mar 4, 2005 10:15 PM
