a friend of mine has a 06 psd 4x4 f350 dullie and it will not go into 4 wheel low.He has put the tranny in nutral and the switch on the dash to 4 low but it dosen't engage.is this a warranty problem or is he not doing something right?
Well on the 6.0 PSD it is on the Passenger side fender.
I don't remember the location on the 7.3L i will have to look and post back.
If you look under your hood you should be able to spot the hard plastic vacuum line and trace it back to the pump. The line usually T's after the pump with a line running through the firewall into the interior of the cab and a line running over around the engine compartment etc.
i always have had the manuel lever for this reson, but the trick i have seen is shift to 4lo while in D going around 3-5mph put into N and slightly press break to more coast to a stop, then if it dont go in stick it in R and back up, put in N, hit break and roll to a stop. just kind of rock it like that till it works. dont be afraid to let it sit in N at a stop before trying the R...this is also how i have seen to get it to shift out. also is he going strait or turning?
