Auto Tranny servicing
Old Nov 22, 2006 | 08:56 PM
05fuelcutoff's Avatar
05fuelcutoff
Does anbody know how to change the ATF in an Automatic 2005 ranger. is it easy enough to do yourself or is it worth the money to pay for it. also does anyone know if the aftermarket makes an oil pan with a dran plug in it. I know skyjacker makes an auto tranny pan to relace the pan for the fourspeed auto tranny in a TJ wrangler that has a drain plug in it. i figured this would make changing the atf easier and also i think it adds more fluid. anyway thanks for any input anybody has on this subject.
Old Nov 22, 2006 | 09:02 PM
ericsmith32's Avatar
ericsmith32
They have drain plug kits at most parts stores.
http://http://www.partsamerica.com/P...artnumber=4470
Might be a bit cheaper. Or you could find the return line and pump the atf that way. Pump out a gallon and replace a gallon. Or 3 quarts whatever you feel comfortable with.
