Latest flash
Old Nov 22, 2006 | 06:53 PM
shocks24's Avatar
shocks24
Latest flash
I just took my truck in to have the turbo replaced and they gave it the latest flash whick cycles the injectors for about 10 seconds after you turn off the vehicle. Has anyone else recieved this flash? If so have you noteced any differences other than the injectors cycling
Old Nov 22, 2006 | 07:14 PM
TinyOne's Avatar
TinyOne
Had it done on my 05 F350 DRW LB CC 29,000 miles. Has stopped that initial smoke and rough idle at start up. No performance issues noticed. Fully stock.
Old Nov 22, 2006 | 07:39 PM
powderB28's Avatar
powderB28
I've been reading alot about getting the PSD reflashed at the dealership. Is this something you can just take your truck in and ask for or does it have to be when it is already in the shop for other reasons? And does it cost anything if there is no other issues?
Old Nov 22, 2006 | 08:38 PM
TinyOne's Avatar
TinyOne
Some flashes are factory recalls. I think this one is on a complaint(ie: My truck is running rough at start up and smoking) Then they will do under warranty. That is if truck is still under warranty. If out you MAY have to pay deductible. i am sure someone will chime in if I am mistaken.
Old Nov 25, 2006 | 10:16 PM
PaulEnglish's Avatar
PaulEnglish
Latest flash
I just had my California 6.0 reflashed due to the emissions recall and it's horrible!
It holds onto gears longer on change up, and is reluctant to change into top at slow speeds. Feels gutless compared to before which was great. Also It's dropped my mileage towing a 22ft trailer down to 11mpg - used to get 13.8mpg.
So I'm taking it back!
It's stock apart from K+N Aircharger Intake I just fitted - which I'm sure should have helped it...
Anyone have similar experience or ideas?
Old Nov 25, 2006 | 11:02 PM
blackhat620's Avatar
blackhat620
First off welcome to FTE lots of good people and info around here
Sorry to hear about your mileage decrease, but be aware that winter diesel fuel is now at many of the stations, and this will reduce fuel mileage.
As far as the K&N intake goes, it will do Nothing Good for your 6.0. The K&N system along with all A/M air intakes for the 6.0 can and will lead to dusting of your turbo and engine. Also FMC is noted for not honoring any warranty claims on the motor with and A/M intake installed. It has been proven many times at FTE by the guys who race the 6.0 that the factory Donaldson air filtration system is the best system on the market. The factory stock system flows more air than the engine can use until you get to Extreme Mods (more than a tuner and exhaust). Also the only way the A/M intakes flow more air is to increase the hole size in the filtration media, thus letting more dirt into the engine. Word to the wise, remove your K&N intake, reinstall the factory Donaldson system and return your K&N for a refund.
Hope this helps
Old Nov 27, 2006 | 10:57 AM
PaulEnglish
Thanks for the advice Blackhat.
Re the A/M intake, mmmm I see what you mean - given the hype and reputation of the K&N especially I'd have thought it would have been safe and improved performance and/or mpg.
I have to confess I just wanted to DO SOMETHING! I've read all sorts of posts from owners with major mods, but overall I've been real happy with my stock truck....until the last flash which really changed it.
Re Winter diesel - I didn't realize it made so much difference 2+ mpg?
Question? What mpg to guys with big trailers and 5th wheels get towing? I really thought that a modern big, low stressed V8 would have done better than 11 with my small trailer (cruising at 65).
Old Nov 27, 2006 | 11:22 AM
blackhat620
PaulEnglish,
"given the hype and reputation of the K&N especially"
Key word here is "Hype" more hype than substance.
If you want to make mods to your truck, first choice should always be gauges (EGT, Boost, Trans Temp), Coolant Filter, Exhaust.
Yes winter fuel can make a big drop in MPG and performance due to the lower BTU's available in winter fuel.
MPG towing heavy can vary alot depending on terrain, driving style, ambient temp, etc. When i tow heavy (15K - 22K GCW), MPG varies from 8-12.
Hope this helps
Old Nov 27, 2006 | 11:47 AM
usroute66's Avatar
usroute66
Paulenglish, I have a Cali model and experienced exactly the same thing. Fuel economy dropped 2 mpg, power is way down, rpms are way up to get even close to the same boost, and it does hang onto the gears longer. I find just letting off the throttle a little will get it to shift sooner. When you get it figured out, let me know. The dealer claims this is expected from the flash (he says they have detuned them - disputed by some on here, yet others have had similar problems after the flash), and the tech I talked to claims he may have an idea (related to some tube drain change on the turbo) but can't touch it until it throws a code or leaves me on the side of the road. Good luck.
Old Nov 27, 2006 | 11:51 AM
Bob Ayers's Avatar
Bob Ayers
Hope this helps
Great post Blackhat!!! We have the same opinion when it comes to aftermarket air filters, and intakes!!!!
Old Nov 27, 2006 | 12:14 PM
AuRevoir's Avatar
AuRevoir
I had the snap ring replaced on the transmission, now when I engage the tow/haul button, it does not drop down a gear to help slow the truck down. Service writer says the new flash reprogrammed the transmission. I would like to have the old settings back.
Old Nov 27, 2006 | 12:26 PM
reefman's Avatar
reefman
Well I had mine flashed last week and I've noticed no difference, just the injectors cycling after i shut the engine off(kind of annoying, but it's supposed to help in the long run). As far as tranny differences, again none. I just pulled my 22' tt and the tow/haul worked just fine, down shifted and eveything as normal. The tech who did your flash possibly could not have completed it, thus giving you your issues? I've heard this account many times by others here, but I'll let them chime in on that.
Old Nov 27, 2006 | 12:47 PM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Do not confuse the emissions recall which is covered under warrenty and came out several months back with a "revised PCM program" to cycle the injectors. Yes, this is a revised PCM flash... but is not "mandated" like the emissions recall.
1) Try unplugging both batteries.
2) Open a door to clear all power from all fuses
3) Wait 5 - 10 minutes (have a beer).
4) Reconnect both batteries
5) Start truck and let idle for 5 minutes (lets PCM relearn EGR closed at idle)
6) Shut off - restart - let idle for 5 minutes
7) Drive truck for 20 minutes or more at varying speed to allow PCM and TCM to relearn driving habits and shift points. Must shift through all gears a few times.
8) After doing step 7 for a while - more time is better than less... let us know what you think and how your truck behaves.... I would think it may improve!!!
Good luck,
Old Nov 27, 2006 | 03:55 PM
usroute66's Avatar
usroute66
Beachbum,
Those of us in California were stuck with the emmissions recall that is very manditory. We can not re-register our trucks until it is done. I too tried the battery disconnect and it did not make any improvements. It definately affected something, the same as Paulenglish...exactly the same. Maybe it is a Cali issue only.
