heater fan trouble
Old Nov 22, 2006 | 10:26 AM
lafer514's Avatar
lafer514
heater fan trouble
heater fan works on high only, sweating or freezing how to trouble shoot
Old Nov 22, 2006 | 10:35 AM
RangerPilot's Avatar
RangerPilot
It's the speed regulator, and for the life of me if I could find my shop manual I'd tell you more.
What year truck?
It should be on the front of the heater fan/blower box in the engine compartment.
Old Nov 22, 2006 | 11:10 AM
lafer514's Avatar
lafer514
its an 01 ranger put new fan in didn,t help
Old Nov 22, 2006 | 11:29 AM
pawpaw's Avatar
pawpaw
Probably the fan speed wire wound resistor pack, located underhood passenger side, close to the firewall, in the A/C-heater air duct
A electrical connector & a couple of screws, will remove it.
Let us know what you find.
Old Nov 22, 2006 | 11:42 AM
Bob Ayers's Avatar
Bob Ayers
I agree, it's the blower resistor assembly.
Old Nov 22, 2006 | 12:46 PM
lafer514's Avatar
lafer514
thanks found the assembly. called the parts store seems to be dealer part, so unless there is an easy test will have to wait till after holiday
Old Nov 22, 2006 | 01:37 PM
pawpaw's Avatar
pawpaw
Well pull the resistor assy out of the air duct & inspect the resistor wire connections to the electrical connectors on the assy.
Seeing a how ALL slower speeds are noperative, I'll bet only one lead wire is open.
You may be able to fashion a splice, or temporary fix, until you can come by a new one after the holidays..
On two occasions, I've fashioned fixes for open, wire wound resistors, from retractable ball point pin springs, using my calipers to gauge the proper wire diameter & ohm meter to trim the wire to the needed resistance length.
Drilled out the rivit holding the faulty open circuit resistor & replaced it with my homemade one, held in place with brass screws & nuts from my "junk" drawer, in place of the rivit.
Beat the heck out of the $120 bucks Toyota wanted for a complete heater/fan speed control assy, for the daughters 77 Celica!!!!!
When she sold that puppy in 97, that home made fix was still in place & working fine!!!!!
Just some scheming & conniving thoughts to ponder!!!! lol
Old Nov 27, 2006 | 08:34 PM
pgw85706's Avatar
pgw85706
Lafer514.....I have the same problem. Have you completed the replacement of the blower resistor assembly and did it resolve the problem?
Old Nov 28, 2006 | 06:04 AM
Dan Robertson's Avatar
Dan Robertson
I had the same problem with my 98 Ranger. I replaced the resistor and it worked, for a few months. It ended up being the wire connector itself. The dealer wouldn't sell just that connector. They wanted to sell me the whole wiring harness. I thought it over and decided that if I went to a junk yard, I would probably be getting the same problem. I put new terminals on all of the wires and connected them individually, using an ample amount of dielectric grease. It has been working fine ever since.
Old Nov 28, 2006 | 02:49 PM
pgw85706's Avatar
pgw85706
Replaced resistor assembly ($19.25) fixed my problem. The connector was cooked pretty bad so replaced it too ($14.64). I believe water gets into the connector and shorts out the terminals so put a good coat of electrical tape around the connector backside. Thanks again to the postings.
Old Oct 21, 2007 | 06:08 PM
wrestlingterp's Avatar
wrestlingterp
Blower resistor assembly part number?
Anyone know the part number for the blower resistor assembly for the HVAC of my 1998 XLT 3.0?
Thanks.
Steve
Old Oct 23, 2007 | 04:45 PM
lafer514's Avatar
lafer514
fan blower resistor part #
I do not know the part #. I took mine apart ,water had gotten in and corroded the contacts where the wires connect. I cut the wires back bought new connectors soldered them in and wraped the whole thing in waterproof tape. Its been 11 months still works fine.
Old Oct 24, 2007 | 07:46 PM
matthew71's Avatar
matthew71
From the receipt for the one I bought last week for my 98 XLT 3.0, it is 4LSZ-19A706-AA. The part number for the wiring harness is 91-6881. Total price for the two of them was about $48 plus tax (at inflated Canadian prices - may be cheaper in US). Take it apart before you drive to the dealer just to make sure you don't need both (I had to make 2 trips).
