Boost concern
Old Nov 22, 2006 | 10:05 AM
2006PSDSD's Avatar
2006PSDSD
Boost concern
I installed my Autometer Phantom guages on my '06, and was a little concerned that my boost may be a little high for being stock. I was running up a hill, WOT with no load, and was pulling 29 psi of boost. I mounted a compression fitting to my intercooler pipe about 6-8 inches from the turbo, so I hope that is in a good place (best place that I could see). I only have a 4" turbo back exhaust, until I get home tonight and install my SCT, and I'm a little concerned that the SCT may increase my boost pressure to unsafe levels. Does anybody have any experience with this?
I also noticed that the stock boost guage is way off from the Autometer. Is that the difference between mechanical, and electronic sensors?
Old Nov 22, 2006 | 10:08 AM
BowTieHatr's Avatar
BowTieHatr
you are reading turbo output, not boost. you loose boost through all the piping and the cooler. the best place is to tap into the system after the cooler to get more accurate readings.
Old Nov 22, 2006 | 10:14 AM
2006PSDSD's Avatar
2006PSDSD
Do you happen to have a pic of where you mounted yours, that is if you have an aftermarket guage. I saw a picture of someone elses install and I mounted mine in the same place. Thanks
Old Nov 22, 2006 | 11:17 AM
BowTieHatr's Avatar
BowTieHatr
sorry i just work on them. you can tap into the map hose location, or the elbow inlet of the inlet.
Old Nov 22, 2006 | 11:30 AM
Bear Hunter's Avatar
Bear Hunter
Yeah...as mentioned above you can do either.... but I would recommend drilling and tapping your intake elbow... tapping into the MAP line will give you some boost flutter at higher psi's. Here is my setup with an Accufabracing Power Air Inlet (they come pre-drilled and tapped), but you would remove your stock elbow and drill a hole using 21/64" or Type R (.339") bit. Tap it with a 1/8 NPT tap.
Old Nov 22, 2006 | 03:10 PM
kw5413's Avatar
kw5413
Good pic B.H.
BTW: Where's the pics of the new beast?
Old Nov 22, 2006 | 04:27 PM
2006PSDSD's Avatar
2006PSDSD
Thanks guys. I feel like a dumb***!!!
Old Nov 22, 2006 | 08:05 PM
ford4lifer's Avatar
ford4lifer
I'm running a 4" turbo back with SCT on xtreme street and I'm seeing between 30 and 32psi and that's kick'n it in the ***. Mine's mounted were Bear's is. Been having too much fun on xtreme street to return it to stock to see what boost it running!!
Old Nov 23, 2006 | 01:02 AM
Bear Hunter
Originally Posted by kw5413
Good pic B.H.
Gallery is up
Old Nov 23, 2006 | 09:05 AM
kw5413's Avatar
kw5413
Stunning. Absolutely stunning.
Wouldn't be able to get my happy butt up in that sucker though...getting too old and toooooo BIG
