Alternator replacement?
Old Nov 22, 2006 | 08:07 AM
powerman6.0L's Avatar
powerman6.0L
Unhappy Alternator replacement?
I think I need to replace my altenator or get it off to have it checked for that matter. My question is how do you get the serpintine belt off so I can unbolt the alternator??? Is there a tensioner? If there is I havent been able to spot it. Its a tight squeeze and I cant seem to find one. Just need a little guidence or a simple how to would be even better. I tried to search but I noticed there isnt a search icon anymore, where did it go? I appreciate the help. I have to get this issue checked out before I get left stranded some where. thanks
Old Nov 22, 2006 | 09:24 AM
Lonewolftx's Avatar
Lonewolftx
Arrow Look here . . .
1st you need to have 25 posts to use the current search engine. It should be up for you now.
Second there should be an engine pic on yur grill cover under the hood showing you your engine configuration and where the tensioner is.
Old Nov 22, 2006 | 09:30 AM
blackhat620's Avatar
blackhat620
[QUOTE=Lonewolftx]1st you need to have 25 posts to use the current search engine. It should be up for you now.QUOTE]
Well not exactly... It changed again on 11/20/06
"Search is now turned off again for non-Club FTE members and non-staff.
We must take this step. I just came back today from 3 weeks of business trips and I'm simply too far behind to consider installing the load balancer and additional equipment. Search will be off like this at least through the end of December." -Webmaster
http://www.ford-trucks.com/forums/54...is-slow-2.html
Hope this helps
Old Nov 22, 2006 | 03:57 PM
powerman6.0L
Yeah I cant wait until hte search engine comes back up. I looked at the picture under the hood and its a little confusing! Thanks for the info guys. Anyone else with some alternator advice?
Old Nov 22, 2006 | 04:41 PM
vloney's Avatar
vloney
The tensioner is on the passenger side, down low. It isnt an easy job for anyone, tech or not. I usually have someone to help me with a serpentine belt tool. You can get it from the top, it will loosen just enough to get the alt off.
Old Nov 22, 2006 | 05:22 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Generally you can pull hard enough on the belt to pull the belt off the pulley, then keep it tight and zip tie or duct tape it to the fan shroud. Change the alternator and then pull the belt back on.
It doesn't have enough tension on it to prevent you from doing it by hand, just be careful not to let it fall off the other pulleys. I have changed several this way.
Old Nov 23, 2006 | 09:56 AM
beemr's Avatar
beemr
There is a small spring-loaded lever on the bottom of the tensioner that is easily reached while laying under the truck. Have a friend pull up on the belt while you push the lever up. It will hold the tensioner unloaded while you do your work.
After all new parts are in place, pull up on the belt, and the lever will spring away, putting tension back on the belt.
Oh, and if you have trouble pulling the belt, a 1/2" breaker bar will fit into the pulley of the tensioner, allowing you to lever it up.
Old Nov 23, 2006 | 11:19 AM
powerman6.0L
Thanks alot everyone! I will tackle it this weekend and hope it fixes the problem. Im very glad I found this forum, everyone has been a great help.
scootro
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sep 19, 2007 10:57 PM
duden123
Sep 10, 2006 12:32 PM
250FordTruck
General Automotive Discussion
Jul 11, 2005 02:54 PM
Muddweiser
1978 - 1996 Big Bronco
19
Jul 28, 2004 07:37 PM
dland
Oct 16, 2002 08:23 AM
