Motor Mounts
Old May 24, 2002 | 08:38 PM
medicpg's Avatar
medicpg
Post Motor Mounts
I am putting a 302 into my 1954 F100 and someone tolld me I could fabricate my own mounts. Anyone got any idea how to do this?
Paul@thepc-medic.com
Old May 28, 2002 | 09:31 AM
tgregoire's Avatar
tgregoire
Motor Mounts
Old May 28, 2002 | 10:01 AM
29abone's Avatar
29abone
Motor Mounts
[updated:LAST EDITED ON 28-May-02 AT 11:02 AM (EST)] Position the 302 where you want it, centered side to side, carb flange level front to back (3 degrees down in back if injected), fore and aft to clear the radiator. If necessary, the eng can be offset an inch or so to the right for steering clearance. Block in place and fill the space between the mounts and the frame. It is helpfull to construct the mounts out of cardboard first, creating a pattern. Make sure the mounts are gusseted and strong. Bolt on or weld to frame. Mount kit can be purchased for $55 at Mid Fifty.
Good Luck
Larry
Old May 29, 2002 | 07:39 AM
wosborn's Avatar
wosborn
Motor Mounts
Classic Performance Products actually makes most of the mounts that the others sell. Try them (no relation).
Pauls47
1947 and Older Ford Trucks
Aug 16, 2010 08:23 PM
djpahan
Aug 11, 2010 12:05 AM
pmasley
West Virginia Chapter
15
May 1, 2006 09:28 AM
paul76gs
Nov 11, 2002 03:32 PM
