Sponsored by: Real Truck
Vibration When Towing
Old Nov 21, 2006 | 04:53 PM
PU70's Avatar
PU70
I was towing a pickup on a 18" flat bet total weight about 6500 lbs. Going about 60 to 75 I would get this vibration that would last about a min. then everything was fine then it would come back in about 10 min. This went on for 200 miles. I live in south FL so it happened on smooth blacktop. When not towing it never happens. Plus this is the first time I towed with the SD. Truck is a 2WD 06 SD with a 6.0 super cab and a LWB with about 6000 miles on it. It was definitely not coming from the front end. What do you guys think. Thanks
Old Nov 26, 2006 | 06:34 PM
Tarponone's Avatar
Tarponone
had the same issue with my 05 excursion 4x4..only towing a 2k lb boat. wish i knew as well.
Old Nov 26, 2006 | 08:20 PM
ReAX's Avatar
ReAX
Just a shimmy in the back end? Quite possibly some shakes and bouncing was tranfered forward from the trailer. Trailer suspention aren't nearly as nice as trucks have become. Plus with the diesel and at speed, you couldn't hear it if the trailer was cracking and banging around.
Don't know if that's your problem, but it is very likely.
Old Nov 26, 2006 | 08:44 PM
PU70's Avatar
PU70
I have towed this trailer before with other trucks and never any vibes. So I don't think its the trailer.
Old Nov 26, 2006 | 09:14 PM
ReAX's Avatar
ReAX
So much for the easy explaination. With gas motor and 3.73 gears I can feel when the AC compressor engages while towing. How about that?
Old Nov 27, 2006 | 07:18 PM
SUPERDUTY_untouchabl's Avatar
That is what the first thing that popped into my head was. Could you feel it vibrating or did it sound like a vibration?
Old Nov 28, 2006 | 09:06 AM
PU70's Avatar
PU70
No I cant feel the AC compressor when it kicks in. And I don't hear it I feel it. If you were to put a cup of water in the cup holder on the dash with it about 1/4 full and going on a smooth road everything would be fine but when it starts to vibrate it would empty the cup.
Old Nov 28, 2006 | 10:16 AM
bryyce62's Avatar
bryyce62
I've noticed that when I don't take my boat out for a couple of months, I get this horrible vibration the next time that I take it out. After a few miles it disappears. I figured that it was the trailer and/or the tires on the trailer. Trailers normally have bias ply tires and are sometimes succeptible to flat spotting as they age.
gw
Old Nov 28, 2006 | 04:00 PM
Big Orn's Avatar
Big Orn
How much does the weight lower the rear of your truck? It could be a carrier bearing (swing bearing) trying to go south on you. Chock the tires, crawl up under it, and see if the rubber around the carrier bearing looks ragged, worn, rough.
