Clutch Help
Old Nov 21, 2006 | 08:01 AM
Ford_dad's Avatar
Ford_dad
Clutch Help
Good Morning Everyone. I have a stupid question that i should know how to do but here goes, how hard is it to replace the slave cylinder on a '99 F250 6 speed. And where is a good place to get one? NAPA? Dealer? Is it a real PTA or not bad? Any tricks i should know about??? Any info would be helpful.
Thanks Joe
Old Nov 21, 2006 | 04:17 PM
pullinair's Avatar
pullinair
What are youre problems with youre existing one?
A pre-bled ford oem slave/master cylinder set-up from a vendor on this site or youre local dealer will do the job. Part# 2C3Z*7C522*C. $154.00. It takes 15 min to put this thing on and is well worth every penny to get this set-up.
Old Nov 21, 2006 | 04:24 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
2C3Z-7C522-C
I sell it for $111.29
Ed
Old Nov 21, 2006 | 04:33 PM
Uzumati's Avatar
Uzumati
I recommend "discountfordpart" he has gotten me excellent pricing on OEM parts and has even helped identify a few i could not find.
Old Nov 21, 2006 | 04:44 PM
Ford_dad's Avatar
Ford_dad
Thanks guys, the problem is if your sitting at a stop light with the clutch pressed down; it is fine for a few seconds but then you can feel it starting to lug the motor. If you have ever tried to pull a truck out of gear while the clutch out, well you get my point... I am thinking that is the problem anyway...
Thanks Joe
Old Feb 11, 2007 | 02:55 PM
bhd's Avatar
bhd
How do you do it? Any advice?
I'm about to get started!
Old Feb 11, 2007 | 03:52 PM
bhd's Avatar
bhd
I have a question about the slave... do you clip the plastic retainer, or does it automatically break upon install? or do i just push the pedal and break it after installation? if you know... please call me at 555-867-5309 (i'll delete this after help... my garage is a block away from my apt...)
I ALREADY GOT IT IN,,, everythings working... nevermind~!
Old Feb 28, 2007 | 06:26 AM
bc56845's Avatar
bc56845
I just bought this kit from the dealer. Is it supposed to come with a master cylinder pushrod? If not, how are yall getting the old rod of the old cylinder to reuse?
Old Feb 28, 2007 | 10:38 PM
bhd's Avatar
bhd
no pushrod. mine came out on it's own. There was a snap ring holding it in that broke. I had 100k, so i replaced the whole system. The new one is a different design inside. a tube with two cutouts that pinch in, so when the rod goes back in, they snap behind the depression at the end of the rod.
If you yank on the clutch hard enough, it'll pop out.
Al Yelton
Sep 17, 2022 04:24 PM
Grizzly93
Large Truck
13
Jan 4, 2015 05:50 PM
ltharper
Jun 30, 2014 10:51 AM
scrobbie
Jan 29, 2014 01:54 PM
Christof13T
27
Feb 18, 2013 01:24 PM
