wild temp readings
Old Nov 20, 2006 | 08:59 PM
dbrown13's Avatar
dbrown13
wild temp readings
93 F-150 SC 300 six, going uphill temp increases, going downhill, temp decreases, am I fighting an air bubble??
Old Nov 23, 2006 | 08:59 AM
holland501's Avatar
holland501
Have you done any work recently that required you to drain and refill the cooling system? If not, then it's probably not an air bubble. The first thing I would check is the fan and clutch. I might consider a new thermostat also, considering the age of the truck. Also, check the radiator for trash. 14yrs can collect a lot of dead bugs etc. There are other things to check but these should keep you busy for a while. Good luck.
Old Nov 23, 2006 | 09:11 AM
dbrown13's Avatar
dbrown13
I had replaced the radiator a while back along with a new cap. I decided to replace the thermostat, because after running the truck on level ground the problem was still there. Replacing the thermostat resolved the problem. I also flushed the system before replacing the thermostat. Thanks for the info! This a great forum!!
