Variable speed wiper switch revisited
Old Nov 20, 2006 | 07:40 PM
SpcLrdGregor's Avatar
SpcLrdGregor
Few weeks ago I posted askin bout switching my 2 position wiper switch out for a variable speed one. I now have the switch, but someone had mentioned a module that plugged inline between the new swtich and the wires to the motor. Does anyone know where I can go and get this module? Is it something An auto parts store would have? If so, whats it called technically. If its a junkyard part, where would I find it in the donor?
The Admiral
Old Nov 20, 2006 | 08:25 PM
quicklook2's Avatar
quicklook2
it is behind the glove box attached to the heater box.
Old Nov 20, 2006 | 11:18 PM
NORTY1's Avatar
NORTY1
if you need a new module/governor there is a website you can get a catalog with that and a whole lot more parts. LMCtruck.com
Old Nov 22, 2006 | 10:14 AM
Lone Wolf #2's Avatar
Lone Wolf #2
LMC has the governor listed and Ford still sells it. The same unit was used in Ford trucks until the design changed in 92.
Old Nov 22, 2006 | 10:39 PM
bas157's Avatar
bas157
Are you looking for something like this? The box looks pretty much the same, as well as the plugs. This is one from my jeep, but some fords used a part that was practically identical (the jeep one has an extra wire and connector in the plug). If this is what you are looking for, I've got a few Ford ones for sale, just have to make sure I still know where in my garage they area!
The Ford ones have a metal mounting bracket on them as well.
