91 Explorer window motor.... help...
Old Nov 20, 2006 | 04:57 PM
amyL.'s Avatar
amyL.
Hello* I know this is a very simple thing I am doing but I still need some help if you please**I have a 91 Explorer Eddie Bauer and my window behind the drivers side will not do anything anymore so I want to change out the motor- only problem I cant get the door apart- I took two black screws out of the door handle- which loosens it up a bunch but I'm just afraid that if I keep pulling I might rip something. Anybody know of any other screws??Or should I just go for it and pull??
Thanks
amyL.
Old Nov 21, 2006 | 06:09 AM
95EXPLODER's Avatar
95EXPLODER
Only thing besides the 2 screws is x-mas tree fasteners. I sugest using a putty knife or something flat and wide to get behind the panel and pry with.
Old Nov 21, 2006 | 12:46 PM
amyL.'s Avatar
amyL.
Thumbs up thank you**
thanks we just ripped it off last night and found a paper sheet tacked to the door another adventure-wish us luck- what does a window motor look like??
amy L.
Old Nov 22, 2006 | 11:01 PM
kevin74656's Avatar
kevin74656
Here are a couple pictures of the motor, courtesy of NAPA:
http://www.napaonline.com/masterpage...r+-+Right+Rear
Old Nov 22, 2006 | 11:11 PM
amyL.'s Avatar
amyL.
you rock
Wow* thats great, thanks for taking the time to show that to me*
Wish me luck on switching it out
Thanks again
amy L.
Old Nov 23, 2006 | 05:15 AM
marragtop's Avatar
marragtop
Before you switch it out, I suggest you use a test light and make sure you are getting power to it. Test it in both the up and down modes.
Old Nov 23, 2006 | 09:58 AM
maa139's Avatar
maa139
If the back is the same as the front, you'll only be able to see two of the three bolts that hold the motor in. Look carefully at the door, and you'll see a dimple in the sheet metal where the third bolt goes. Just drill a hole for access to the third bolt. I changed the motor in one of my front doors, and the whole thing took about 15 minutes. A very simple fix. Added bonus was that I got the 'new' motor on ebay for $5! The problem with my window was sporadic. I put a voltmeter on it, and the motor was only dropping 9 of the 12 volts that were feeding it, so there was a short in the windings. Good luck!
Matt
