Sponsored by: Auxito
waterpump help
Old Nov 20, 2006 | 04:19 PM
thebest1tom's Avatar
thebest1tom
thebest1tom
i need to find the instruction for changeing a water pump on 97 f150 v-8
Old Nov 21, 2006 | 09:12 PM
Beast12's Avatar
Beast12
Thread moved.
-Matt
Old Nov 21, 2006 | 10:40 PM
LxMan1's Avatar
LxMan1
Welcome to the forum.
These are pretty easy, not much in the way.
Remove the anti-freeze, fan/clutch assembly, belt and pulley. Remove the 6 bolts (I think) and pry it out or tap on the shaft to work it loose. It uses an o-ring instead of a gasket so sometimes they are kinda tight in the block.
