Without the glows, ether is safe to use if you don't use too much, just a quick snort(half a second at most) in the air intake should be plenty to get it fired up. If you need more than that, you have problems other than just not having working glow plugs...
I'd MUCH rather use ether than a rag soaked in gas... But, that's just me....
ether can be used SAFLEY in our idi's IF you either disconnect the glow plugs or wait 3 minutes for them to quit cycling & cool before spraying. be sure to use a brand that has a top cylinder lube included.
wd40 will work on any diesel ive used it many times on my old cummins in my cabover kenworth, if your gonna use either after you tern the key on and the glowplugs cycle dont shut the key back off leave it on so the wont cycle again
Personally, I'd just rather stay away from ether for my IDI. Too risky IMO. That is why I started this thread in the first place.
I can't help but notice that Dave, Spectramac, farmnfly, cookie88, PLC7.3, KJLYPW, and a few others I'd like to hear from on this topic haven't chimed in yet
So, if you had to use something in a pinch, what would it be guys?
WD40? Ether? Carb cleaner? Gasoline? Or something else?
If I had a reason to use a starting aid other than glow plugs, I would use ether.
Since my glow plugs are manual I could eliminate the worst problem with using ether by not pushing the button.
If the engine is in proper operating condition, you should have no need for any starting aid.
I have cranked mine up at temps well below zero when it was not plugged in by cycling the glow plugs twice before I cranked the engine. Started just like it was 70 degrees outside.
So I guess my position on this is if the truck is kept in a well maintained condition, you should never need to use any of the other starting aids.
Remember, I am an old school truck driver and farmer. Back in the 60's and 70's before glow plugs were common that is what you used to start diesels in low temperatures.
i have a small mulch company in central florida, the john deere tractors (wheel loaders) i have been replacing have had cold start issues since new. the tractors that are the oldest are so low on compression that when the are shut off for whatever reason they will not restart!!! the gas soaked rag works every time!!! you get a little gear oil quart bottle that is empty (the kind with the nipple on the end for "squirting") and fill it with gas, then you have the bottle to reuse all the time, a few drops is all it takes. i have done this for years and have never had a tractor not start that way. that never causes the high rev that ether causes when the engine starts, i have however had an ether fired john deere break on start up, due mostly to it being worn out, but the fact that the ether start caused the dry engine to fire at redline for 5-6 seconds didnt help.
hope this helps
if you got a block heater use it and you wont have to use either of wd40 to start your truck
I have a block heater and don't need to use it. My truck starts fine. I've stated this fact and asked my basic question two or three times so far in this thread, but I'll ask it one more time.
I'm looking for an answer as to what's the best thing to use when something goes wrong and it doesn't want to start. It will happen, eventually. That's a given. When it does, I'll address and fix whatever is wrong. BUT, in the event that I need to get it started, and don't have time to fix it on the spot, if ether is bad, which is a better substitute, WD40 or carb cleaner?
I'm thinking carb cleaner - for the reasons I've stated previously in this thread - two or three times.
Cheaper,
Enee, Meenee, Minnee, Moe....I really don't think your going to really get a concrete answer on this one.
And according to Dave, you shoudn't ever have to!
I'd stick with your carb cleaner, but if you want your IDI to smell nice and look good then I'd go with the hair spray
LOL! I'm pretty well convinced you're right on that one. No definitive answers to be had. So far no one has come up with anything WRONG with the idea of carb cleaner. Though there has been at least one person state a reason not to use WD40, and we're all familiar with the arguments against ether.
So, unless someone can give me a good reason NOT to use it, I guess its carb cleaner for emergency starting for me.....
I finally got bored enough to check this one out.
Yeah, take yer pic. If it's an emergency, use whatever you can find. I like the idea of WD-40, but always end up using either (sparingly from a warm can).
