'94 Highbeams won't function
Old Nov 20, 2006 | 12:52 PM
Autospirit's Avatar
Autospirit
Have a '94 F150 4.9L
If I flip the multifunction switch forward with the headlights on, the highbeam indicator on the dash illuminates, my lowbeams cut out(as they should) but the highbeams don't go on.
If I just use the flash-to-pass, again the dash highbeam indicator works, but my brights don't.
I've checked all possible fuses and they all were OK. I don't think it is the multifunction switch because the dash highbeam indicator still works?...
Any ideas?
Old Nov 20, 2006 | 12:53 PM
quicklook2's Avatar
quicklook2
bulbs are burned out?
the high beam part.
Old Nov 20, 2006 | 12:56 PM
Autospirit's Avatar
Autospirit
Could be...I just thought it was strange that both went out at once.
Is there any way I can use a multimeter to check that?
Old Nov 20, 2006 | 01:06 PM
quicklook2's Avatar
quicklook2
look at bulbs first for a burned filament.
Old Nov 20, 2006 | 02:35 PM
scottie2hottie's Avatar
scottie2hottie
i think if the relay blows the dash light still illuminates- i could be wrong tho
Old Nov 20, 2006 | 02:42 PM
compaddict's Avatar
compaddict
I vote burnt out bulbs...
Vince
Old Nov 20, 2006 | 03:30 PM
Autospirit's Avatar
Autospirit
Burnt bulbs it is.
I was just confused by the fact that they both went out at the same time. Could that be a sign of a fault somewhere else?
Anyways, I went all out and bought some Sylvaina Sliver Star bulbs...I'll let you guys know if it was worth it...though my foggy lenses probably won't do them much justice.
Old Nov 20, 2006 | 03:47 PM
quicklook2's Avatar
quicklook2
get plastic cleaner and clean the lenses. silverstars are good.
Old Nov 20, 2006 | 09:54 PM
Autospirit's Avatar
Autospirit
Yes, the silverstars are good.
Definitely brighter and whiter. They also seem to spread more of an even flood of light.
Worth 40$ ? They're nice, but we'll see how long they last.
Old Nov 20, 2006 | 10:13 PM
quicklook2's Avatar
quicklook2
bulbs have lasted 3 years so far in my subaru.
check the website for any rebates.
i had sealed beam silverstars in vehicles for over 5 years and they were still working when i sold them.
