U-joint replacement.
Old Nov 20, 2006 | 11:37 AM
RangerPilot's Avatar
RangerPilot
Eh...it's getting 'bout that time, mine are worn out, I can feel the slack in the driveline at times.
Where did you guys who have done it before get your replacement joints from, how much were they, and what do I need to watch out for when replacing them?
Thanks.
Old Nov 20, 2006 | 11:51 AM
Bob Ayers's Avatar
Bob Ayers
Zach, are you going to do it, or taking it to "our" mechanic????
Normally the symptoms of bad U-joints include a bad vibration under load (while accelerating).
Old Nov 20, 2006 | 12:00 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Have you actually crawled under there and inspected for loose u-joints or is this an assumption. Because I'd expect what's probably going on is that after a zillion miles you've got more backlash in the rearend than when it was new and this is the cause of the looseness.
*This could be a good time to consider jettisoning your current granny gears in favor of numerically higher ones .
Old Nov 20, 2006 | 12:44 PM
RangerPilot
It's got the vibration going on, and the driveshaft can literally be "wiggled" a little bit from side to side.
And yes, I'll be doing it.
Old Nov 20, 2006 | 02:59 PM
drhydro's Avatar
drhydro
Hi Zach,
I just purchased Ujoints for my 99 b-3000 3.0 litre at my FLAPS (friendly local auto parts store) for all of 11.95 per set.
Doc
kev03
May 12, 2009 08:41 PM
chrisf250-460
1997 - 2003 F150
Dec 18, 2007 09:04 PM
gearhead351
Oct 10, 2007 06:28 PM
richep
Dec 1, 2005 03:39 PM
loudfords
Sep 27, 2005 01:50 PM
