Glow Plug Resistance
Old Nov 20, 2006 | 11:20 AM
bc56845's Avatar
bc56845
There's a '93 7.3 that I'm working on with a cold start problem and I need to check the glow plugs. everything that I've read on this site says to just use a test light and see if the plugs are open or closed, but I'm usually on the powerstroke forum and all those guys say to use a meter and actually check the resistance of the plug. Do any of yall check resistance, and if you do what should it be?
Old Nov 20, 2006 | 11:24 AM
Spectramac's Avatar
Spectramac
You want as close to a dead short as possible. I usually see 000-002 set on 2K.
Old Nov 20, 2006 | 11:35 AM
93_E_350's Avatar
93_E_350
I have found that rust can build up between the nut and the upper portion of the plug causing a bridge over the insulator. I pull the plugs and clean this area before testing. Then hold them with a rag or glove or the meter will read through you. If you can clean them off while installed that’s fine too. Either way check them when cold, the resistance will change if they are hot.
Old Nov 20, 2006 | 12:45 PM
PLC7.3's Avatar
PLC7.3
A post from another site.........
If you have 2 or more bad GPs, the controller may not cycle at all.
Two problems that occur with the solid state ( 1987 to 1994 IDI engines ) GP systems. If a GP burns out ( circuit resistance goes up ), the controller cycles the GPs at a faster rate which doesn't let them get to max operating temp. If 2 or more GPs fail, the controller may not cycle the GPs at all ( very rapid or no clicking heard ). When you check the GPs, use an ohmmeter. A high resistance ( not necessarily burned out ) GP can cause circuit resistance to go up and the controller will then cycle the GPs too fast. You probably will not find this problem with a test light. Resistance spec for GPs = .5 to 1 ohm cold. Second problem. A poor controller ground ( black wire attached to valve cover stud ) will cause the controller to leave the GPs on longer, often damaging or failing them. If you are having mulitple GP failures, I would check closely the controller ground. Now the confusing part. Bad ground --> longer GP on time ( slower cycling ). Burned out GPs --> faster cycling If you have both situations, it may appear that the controller is cycling the GPs at the proper rate. Bad ground slows it up while the burned GPs speed it up ---> normal cycling. The system acts/sounds like it's working normally, but you have a hard starting concern.
By........DieselDon
1Fastboy
29
Mar 3, 2016 09:43 PM
corman146
Oct 20, 2015 10:29 PM
dev_jhnsn
20
Feb 20, 2015 07:23 AM
cherrybomb37
Mar 27, 2014 11:22 AM
Yazmar9
Dec 14, 2013 03:52 PM
