Sponsored by: Real Truck
Back window area creaking!
Old Nov 20, 2006 | 10:04 AM
bradcollison's Avatar
bradcollison
Cool Back window area creaking!
I have a 2006 F-250 Crew Cab 4X4 PSD.
I have a creaking noise in the passenger side rear window area.
It makes the sound whenever the body flexes.
Took it to the dealer and they could hear the noise, but couldn't fix it. They tightened some body mounting bolts and that didn't help.
Anybody have this noise? What should they do to fix it?
Old Nov 20, 2006 | 10:38 AM
jim henderson's Avatar
jim henderson
Creaky noises are par for the course. THe truck bodies flex quite a bit and make all sorts of noises. The windows in the back will make noises since the frame they are in is under a little bit of flex stress.
The frame twists and the body and bed try to go their separate ways. Plus the frame twists along it's entire length so the stress is uneven all along the body and the mounts.
Could be worse, I know some cars with T tops that will soak you if you turn up a driveway in the rain.
Good Luck,
Jim Henderson
