Vacuum Diagram - engine swap
Old Nov 20, 2006 | 08:09 AM
scottek's Avatar
scottek
I am putting a 5.8 L & E4OD from a 91 F250 into a 96 F250 and I am need of a good vacuum diagram for the 96. The under hood and repair manual (Chilton's) do not give enough detail. My main problem stems from the fact that the 96 came without and engine. A major difference between the two is the vacuum reservoir, the 91 had two lines/ports where the 96 has 4 ports (2 upper + 2 lower). My vacuum diagrams do not detail the 4 ports.
Thanks for your help.
Scottek
