1978 - 1996 Big Bronco
95' bronco troubles
Old Nov 20, 2006 | 01:31 AM
JustinRoyce's Avatar
JustinRoyce
Exclamation 95' bronco troubles
I just installed a new head unit in my bronco but for some reason the max volume is very low. I also installed new speakers in the doors. The problem still did not fix. I was just wondering if anyone could help me out with this. & one other thing, does the 95' broncos come with a stock amp already installed in them?
Old Nov 20, 2006 | 11:04 AM
poffutt's Avatar
poffutt
Run this tread in the Audio & Video Systems, Mobile Electronics forum. You should be able to get better help there.
Old Nov 21, 2006 | 10:37 AM
460srule's Avatar
460srule
My 95 XLT has a separate amp.It is way up under the dash just to the right of the gas peddle.Follow the wires to it,best I can tell you.With a long extention and socket(10mm,I think) it is actually not that hard to take out.
Old Nov 29, 2006 | 07:52 PM
bills ford toy 4x4's Avatar
bills ford toy 4x4
remove your kick panals on the driver an pass. side an by passwith jumper wires on the high side of the plug an run a new wire from head unit to the jumper be sure to kill the wire or it will burn ur head unit from the fact.amp
