Engine code info
Old Aug 27, 2000 | 02:02 AM
19dan56's Avatar
19dan56
Engine code info
Old Jun 8, 2002 | 06:28 PM
55FordLover's Avatar
55FordLover
Engine code info
I have a y-block with the casting numbers of ECGB015B or ECGBO16B? Can anybody tell me what type of block do I own please!!!!
James
55 Ford F100 (For Sale) Original
54 Ford F100 302/AOD...almost running!!!!
Old Jun 8, 2002 | 06:51 PM
Earl's Avatar
Earl
Engine code info
From the Y-Block web site:
ECG = 272 cu. in V8 used in 1955 to 57 cars and trucks
6015 is the standard Ford part number for all engine blocks. Are you sure that B in the fourth place isn't a 6?
The last B is the revision number. The sources I've read say you can replace parts without compatability issues if the replacements have the same or later revision numbers. So you could use an ECG6015B, ECG6015C, etc. block if you needed a replacement. Maybe somebody else can confirm that.
George
Old Jun 11, 2002 | 02:55 PM
55FordLover
Engine code info
thanks for the help man, I have been trying to figure it out for the longeest. i really appreciate it.
James
55 Ford F100 (for sale) 223/3spd
54 Ford F100 Not 4 Sale 302/AOD :-)
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
