ignition?
Old Nov 19, 2006 | 10:47 PM
factory594x4's Avatar
factory594x4
Question ignition?
Can anyone suggest a good dizzy/ignition setup? To modernize my 79'.
Old Nov 19, 2006 | 11:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
Use a good Duraspark-II system in good order with a Motorcraft module, -works great. The system has start retard which is necessary with many engines (especially high performance or large displacement) for hot starting. Even a "properly set up distributor" will not perform that function. Mount the module with 1/4" spacers on the fender to allow cooling air under the module. You can get a custom curved distributor from Performance Distributor:
http://www.performancedistributors.com/index.html
Old Nov 20, 2006 | 01:47 PM
galaxie641's Avatar
galaxie641
check out the Ford DUI kits from that above link I like the looks of them but not the price. $370 list
