oil pan help
Old Nov 19, 2006 | 08:12 PM
juchertf100's Avatar
juchertf100
oil pan help
hi
im new here was told by a good friend of mine you guys could help me
so my first problem is i am bulding a 1966 f100 short bed .
i am using a 302 from a car i had it bored .60 over the oil pan i am using i bought from ebay says it for truck app. but when i try to put the oil pan on it hits the oil pump not the sump but the pump its self is there a diffrent pan i can use .
please help if you can
302 is a 78 car
thanx juchertf100
Old Nov 19, 2006 | 08:35 PM
airharley's Avatar
airharley
http://www.cantonracingproducts.com/...rear_sump.html
http://flatlanderracing.com/oilssford2.html
These are a couple of places. You may also want to check L&L. I am curious to know if you have a melling m68 or equivilant on your 302. It could be the wrong pump style all together.
Old Nov 19, 2006 | 08:53 PM
juchertf100
i just checked yes it is a melling m68 so i guess i have the wrong pump
Old Nov 19, 2006 | 09:40 PM
airharley's Avatar
airharley
Nope that is the correct pump. I checked from 71 all the way up to 92. I even looked at different models to make sure. What kind of pan do you have? I know you said it was a rear sump but who makes it.
Old Nov 19, 2006 | 09:45 PM
juchertf100
it does not give manuf. but i got it from hotzone #hz-9792-pbk
Old Nov 19, 2006 | 09:53 PM
airharley's Avatar
airharley
http://www.fordracingparts.com/parts...tKeyField=6128
This link is what the pan should look like. I took a gander at the notsohotzone pan. That one just doesn't look right. Contact them and see what oil pump is needed to run that pan. You should have a small front sump like the Ford pan to be able to fit the pump.
Old Nov 19, 2006 | 10:03 PM
juchertf100
thanx
that pan from ford racing says it fits 79-90? will it work for my 78 block and does it matter if it front or rear sump im the f100
Old Nov 19, 2006 | 10:12 PM
Redmanbob's Avatar
Redmanbob
I put a 85 5.0 HO in a 72 Fastback and went through several attempts with Jack@ZZ's from speed shops trying to sell me a hot rod pan that did NOT FIT the application. Finally wound up with a 67 ? low front sump pan for a 302/289 from guess who "your friendly neighborhood ford parts guy" Yep.. worked like a charm.. my 2¢ ask a Ford person get a Ford answer... BOL...
Old Nov 19, 2006 | 10:14 PM
airharley's Avatar
airharley
Best way to find out is mock the block in the truck and measure. Measure from the oil pan rails to the crossmember to see if you will be able to fit the front sump pan. It's easier to take the engine in and out then monkey with a pan that might fit.
I also looked at the dates for production blocks. The 302 is from 83-01 and the 351W is from 69-04. Last I knew all 302's and 351's were identical on the bottom of the block. The 351W has a taller deck hieght mind you. The Canton site doesn't specify what year 302 or 351W blocks as well.
Old Nov 19, 2006 | 10:16 PM
juchertf100
by local parts guy you mean the dealer
Old Nov 19, 2006 | 10:24 PM
airharley's Avatar
airharley
I think he is refering to an actual Ford Parts Dealer. Local auto store employees are lacking in any real knowledge besides what is on the screen in front of them. However with that said there are a rare few that truely know what they are talking about.
Old Nov 19, 2006 | 10:33 PM
juchertf100
thats been my experence thats why iwas asking in my neck of the woods dont nobody at any parts house know a dang thang but whats on that little screen thats what make me thankful for all your help
Old Nov 19, 2006 | 10:36 PM
juchertf100
another ? will my six banger motor perches work for the small block
Old Nov 19, 2006 | 11:07 PM
airharley's Avatar
airharley
That I do not know. I used a universal mount system for my truck. You may be able to post another topic to find out or better yet use the search function to see what it comes up with.
Old Nov 19, 2006 | 11:15 PM
juchertf100
what is a universal mount
