Keyless Entry Code ?
Old Nov 19, 2006 | 02:52 PM
dukman22's Avatar
dukman22
How do you go about finding the keyless entry code ? I just bought a 2000 EB and the dealer did not have the code. Thanks.
Old Nov 19, 2006 | 03:41 PM
bridge's Avatar
bridge
Sick 'n Tired
It's on the driver's side under the front dash up behind emegency brake. Should be a black control box with a bold 5 digit code for your keyless entry.
Old Nov 19, 2006 | 07:02 PM
tsax's Avatar
tsax
Ditto w/ bridge. I bought a used 99 and found mine by laying on the driver's side floor and looking up behind the emrgency brake. A flashlight helped
Old Nov 19, 2006 | 09:57 PM
dukman22's Avatar
dukman22
Thanks very much. I will check that tomorrow. I thought that it might have to be taken to the dealer, so this is good news.
Old Nov 19, 2006 | 10:00 PM
bridge's Avatar
bridge
Sick 'n Tired
FTE forum good. Dealer bad.
Old Nov 20, 2006 | 12:02 PM
scottek's Avatar
scottek
And on the newer Expeditions it is the same location but on the passenger side.
You may need to remove the kick plate plastic?
Old Nov 20, 2006 | 06:07 PM
artfuldodger's Avatar
artfuldodger
Once you have the code under the dash you can recode it to a new 5 digit code of your choice. Check your manual for instructions or let the forum know if you don't have a manual.
Old Nov 21, 2006 | 03:17 PM
dukman22's Avatar
dukman22
With the help of you guys that contributed to my request for help I was able to find the code. Again thanks for your help.
If someone else needs the same info, this is what I found. The code was on a white(translucent) plastic box which was above and to the outboard side of the steering column. It measured approx. 6in. x 3in. x1 1/2 in. thick. There was a sticker which said Ford Electronics (Canada) and the code was in bold numbers(5 digits).
Old Nov 22, 2006 | 02:30 PM
Wolfman2405's Avatar
Wolfman2405
GREAT!!! Saved me $35. I asked the dealer if they could get the keypad code out of a used Expedition and they said $35 and about a half hour. I just went out and got it myself in about 1 min!!!!
Bridge
"FTE forum good. Dealer bad." I second that!!
Old Nov 22, 2006 | 07:59 PM
HomerWinzlow's Avatar
HomerWinzlow
Most newer model vehicles have to have the code retrieved with a scan tool. Unless the service advisor is some genius who knows each and every model and how to obtain their door codes they will just give you the worst case scenario.
Old Feb 5, 2007 | 03:01 PM
kxrider375's Avatar
kxrider375
Cool, same problem except the dealer I called wanted $55 to look under there for me.......
Old Feb 5, 2007 | 07:48 PM
undrdcvrs23's Avatar
undrdcvrs23
Other places to look
I read on another website that some of the newer vehicles the security box the code is written on is behind the radio compartment, if you take the 4 plastic screws loose under the steering wheel and lay on the floor with a flashlight you can see it back behind the radio!
crozz
Iowa Chapter
Mar 7, 2017 12:23 PM
crozz
2004 - 2008 F150
Sep 26, 2016 08:16 AM
3KIDDAD
Jan 17, 2007 09:13 PM
logginhard
May 15, 2004 11:23 PM
bdalexan
Aug 30, 2003 12:25 AM
