Friction Modifier Needed or Not?
Old Nov 19, 2006 | 02:10 PM
Charles1's Avatar
Charles1
I have a leaking rear diff cover and want to change the gear oil in the rear and fix the leak. Do I need a thing of Friction Modifier? Is there supposed to be a special oil I use in the diff other than normal 80/90 gear oil? I bought some Slick 50 80/90 to re-fill it with. Is this ok? Just need some advice.
Old Nov 19, 2006 | 02:33 PM
verticalrich's Avatar
verticalrich
mine had a tag under one of the bolts on the cover that stated 75w140 synthetic only!
the manual agreed and called for 4 ounces of friction modifyer also
Old Nov 19, 2006 | 02:44 PM
Charles1's Avatar
Charles1
What year is yours?
Mine is a 99 and from what the garage I asked told me it uses 80/90. Thanks for the info though, I will double check.
Old Nov 19, 2006 | 02:52 PM
verticalrich
eddie bauer 4x4 5.4
Old Nov 19, 2006 | 02:56 PM
Charles1's Avatar
Charles1
Should be the same then I would think
Should be the same then I would think. Will check tomorrow or Tuesday.
Old Nov 19, 2006 | 09:52 PM
Genes04Expy's Avatar
Genes04Expy
Gear oil
It depends on the type of rear end it has. If it is the limited slip style it will need the synthetic fluid and friction modifier to control the clutches from chattering when turning. A standard rear end w/o clutches can use standard gearoil. Look for a tag on the back plate of the rearend and use what it recommends.
Old Nov 20, 2006 | 09:09 AM
EagleDakota's Avatar
EagleDakota
If you have 4x4 then you should add the modifier. Check some of the posts here - rear diffs are a huge Topic. I would make certain that whatever you use meets the Ford specification. Definitely go to Ford for the friction modifier.
