Coolant Sensor Location
Old Nov 19, 2006 | 01:18 PM
graum's Avatar
graum
1979 F350, 4x4, Reg Cab, 400 engine, C6
A little help please.
My Temp guage has stopped working.
Where is the coolant sensor located?
Thanks
Old Nov 19, 2006 | 02:11 PM
Mil1ion's Avatar
Mil1ion
Look for a spark plug looking thing with a metal nut..... a wire with a 90* connector going to it near the thermostat housing.
Old Nov 19, 2006 | 02:47 PM
graum's Avatar
graum
Thanks!
I looked over it several times but missed the obvious. Chiltons was no help.
Many thanks again
Old Nov 19, 2006 | 02:51 PM
Mil1ion's Avatar
Mil1ion
Here's an illustration of your engine if you need it.
http://www.clubfte.com/users/mil1ion...mDiagrams.html
Old Nov 19, 2006 | 05:16 PM
graum's Avatar
graum
Finally found it. On top of the thermostat housing I've got a pipe T with two vacuum control valves (replace one about a month ago). No wires running to it.
Searching further finally found the temp sensor behind the alternator bracket - on the front of the engine. Connecter was corroded and loose. Sprayed cleaner on it, squeezed connecter with needle nose pliers to tighten, added some dielectric grease and reconnected. Temp gauge seems to be working now.
Thanks for pointing me in the right direction.
