weird cutout when driving
Old Nov 18, 2006 | 05:42 PM
the kid's Avatar
the kid
sometimes when im running down the road in my truck it loses power. its like the motor dies for a split second the raido stays on and the tach dosent move. i cant figure it out.
Old Nov 19, 2006 | 11:34 AM
Dragon22's Avatar
Dragon22
Need more info about the truck,
engine (EFI or Carb), etc.
Sounds like the module for the ignition might have a wiring problem.
Get the module tested to rule it out (the module will work or it won't),
check wiring that feeds to the module,
corrosion can play tricks and cause the problem you descibed.
Old Nov 19, 2006 | 03:27 PM
the kid's Avatar
the kid
its an 84 300 6 with the factory one barrel carb. thanks
Old Nov 19, 2006 | 08:29 PM
the kid's Avatar
the kid
i was reading another post it was kinda the same problem i got the truck a couple of mounths ago and it never did it. but the other morning i noticed sparks under the hood when i tryed to start it i wouldnt roll over it just clicked like a dead battery so i poped the hood and tryed again it was sparking by the starter relay i just wiggled it and it started. and come to think of it thats kinda around the time this started. it also has a push button start
Old Nov 21, 2006 | 10:02 PM
dcrummett's Avatar
dcrummett
First check the distributor for a bad ignition pickup coil. A rebuilt distributor comes with the coil (stator) and runs just over $100.
Old Nov 22, 2006 | 09:41 PM
clunker86's Avatar
clunker86
sounds like you got some bad wires under the hood. i would look over my starter wire and starter relay. i would also check the spark plug wires for and wronen are damaged wire. replace them if needed and make sure the wires on the starter relay are clean and tight
Old Nov 24, 2006 | 08:39 PM
pinaclan's Avatar
pinaclan
i had the same problem and it turned out to be my solenoid was loose and had a bad ground,some times the truck would kick right over and some times not.also added another ground to the block from frame.
