I just did a search on this topic, but came up with nothing. I could've sworn that this topic has been covered before...
Anyways...has anyone ever thought about, or installed cab clearance lights to their '97-'03 F150? I've seen pictures of the new F150's with them, and they look awesome. Im thinking that these lights with a moonvisor will make my truck look bad***!
Is it as simple as running the power wire to a simple toggle switch (or the parking lights), or is there more to it?
Measuring, measuring, measuring, and don't forget drilling holes in your roof. I saw 03 pickup listed with the roof lights, and I wouldn't put them on the 97-03 style pickup. If might have looked ok if they were spaced differently. They looked rather big, and not the style that should be up there. Unfortunatly, I can't get a photo of it.
Time to bump this, as I might make this the next mod on my truck.
Matt, No, I haven't done this yet. I've been trying to do research on it, but no one has done it. I have heard that the Dodge clearance lights fit the contour of the roofline much better than the SD's...but can't confirm that. And I highly doubt the dealership would let me open up a package and test-fit them in the parking lot. Although, couldn't hurt to ask...
Oh, and the reason I bumped this and got the idea back in my head, is because I saw that damn truck again last night. Some guy here has the exact same truck as mine with clearance lights on it and it looks awesome I thought about following him and asking about it...but realized I can't afford the gas to do that...
The SD clearance lights and wiring harness are only $55 from the dealership (last I saw), but the only thing I need to know is if they will fit the contour (curve) of the roofline. I don't want to have a gob of silicone filling in the gap between the light and roof.
Crazy: Another thing you should know is that these clearance lights are a requirement on larger width vehicles. Its not all about "they look awesome.... make my truck look bad***!" They "arrange" the lights as prescribed by law.
Originally Posted by ATC Crazy
I was going to arrange them like the new SD's. 3 in the middle with one to either side"
Many of these clearance lights traditionally required drilling 3 holes thru roof (2 screws 1wire) for a total of 15 holes. You might want to reconsider NOT wanting "a gob of silicone" since preventing rain leaking in can be a serious issue.
The company claims to install them on any truck, and they give you a template for drilling the 15 holes and you can just ground them to the cab and splice the positive into your parkinglight wiring. I'd use a relay so you don't add to many amps to your existing wiring.
When there's the issue of "need to know is if they will fit the contour (curve) of the roofline, I would definitely recommend not relying soley upon those "gaskets". Note that some designs make it easy to modify the bases & you can closely match a curve w/file or belt sander.
Originally Posted by superdutymj
most of the aftermarket lights come with gaskets to prevent leakage.
The high quality, Made in USA, clearance lights I put on my 1st FORD truck came w/foam 'rubber' gaskets that did not last long & soon leaked. Had to go back inside the headliner to remove them & sealed them permanently w/silicone. Note this design was 'bolt thru' w/2 nuts inside. Other designs simply use self tapping screws from outside.
Yes, I know about the federal laws associated with clearance lights.
What I meant by "a glob of silicone", was that I don't want to use the silicone as a filler to fill in the gap that a mis-matched light would cause. I don't want a light with a mounting radius of 4" on my roof with a mounting radius of 10", and have to fill in the gap. I will use silicone (or other sealer) to make it water tight...but just a small ammount...
