duraspark ?
Old Nov 18, 2006 | 12:10 PM
ynotsher's Avatar
ynotsher
Question duraspark ?
what is it and how does it work ,what componets are needed for it to work on 1986 f150 300 six with 4 speed manual trans .
Old Nov 18, 2006 | 12:27 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Old Nov 18, 2006 | 06:51 PM
Franklin2's Avatar
Franklin2
You have put an earlier engine in place or you are converting what you have correct?
Here's a schematic to put a duraspark II in an older vehicle. You will need a duraspark II distributor for a 300 6cyl, a duraspark II ignition box with a blue plastic piece where the wires go in, a starter relay with two small terminals, and have to do a little bit of wiring.
What I would do is go to the junkyard and get what you need out of a truck there. You can use any duraspark box out of any late 70's early 80's Ford/Mercury car or truck. But you will need a distributor out of a 300 6, and I would also get the factory wiring that goes from the dist, to a plug, and then to the ignition box.
