1978 - 1996 Big Bronco
sloppy steering
Old Nov 18, 2006 | 08:47 AM
bubba_d_duck's Avatar
bubba_d_duck
sloppy steering
so whats the first thing i should do to tighten up my steering. its not to bad tell i get on the freeway then coners are a real pain
Old Nov 18, 2006 | 10:34 AM
dwoodler's Avatar
dwoodler
I'd check the tie rod ends and steering linkages. Then the rag joint between the steering wheel and the box. The bearing in the bottom of the steering column sometimes goes too. If that don't fix it then replace the gear box.
Old Nov 18, 2006 | 06:26 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Sloppy? As in too much slack in the steering wheel before it responds? Check the rag joint as dwoodler said and also adjust the slack in the steering gear box.
Sloppy? As in you hold the steering wheel still and the tires go all over the place? Again as dwoodler said check all of you tie rod ends and steering linkages. Also check your upper and lower ball joints on the A arms and the bushings in the A arms. Oh yea, make sure you check your wheel bearings for play.
Old Nov 18, 2006 | 06:56 PM
bubba_d_duck
will do thanks for the help. and its play as in i steer to the right and then have to over steer to get it to go strait again. i think i will start with the gear box. is there a nut to tighten or a screw to ajust the slack? thanks again for the help
Old Dec 3, 2006 | 11:36 AM
bubba_d_duck
i changed the steering box and it fixed my problem. thanks for the help
reed1951
Ford Truck Parts for Sale
May 23, 2015 04:34 PM
beckman
Apr 17, 2013 11:54 PM
monkey533
Sep 20, 2012 08:38 PM
gusso
26
Aug 20, 2007 06:57 AM
cburwell
Oct 23, 1999 03:46 PM
