Mounting trans temp sender...
Old Nov 18, 2006 | 06:36 AM
ford4lifer's Avatar
ford4lifer
Question Mounting trans temp sender...
Where is the best place to mount the trans temp sender? Do I need to drain the trans and drop the pan? Or is there a plug that can be removed to mount it there. I searched the old treads but haven't found the right answer.
Old Nov 18, 2006 | 07:52 AM
npccpartsman's Avatar
npccpartsman
There is a plug on the drivers side just above the the tranny oil pan. I'm NOT going out to crawl under the truck this early--LOL--but that's where my sender is screwed in. You don't have to drill and tap anything--the sender screws right in and your fluid loss would be extremely minimal if any at all.
Old Nov 18, 2006 | 08:44 AM
ford4lifer's Avatar
ford4lifer
Hey great thanks. I'm still waitn for it to warm up here a little 34dg here this am. lol dont blame ya. thanks
Old Nov 18, 2006 | 10:28 AM
raptor131's Avatar
raptor131
yes it's the high pressure test port or something like that. it's the only bolt you should see while looking up at the tranny from the drivers side. i wrapped my sender threads in teflon tape before installing to ensure a good seal. but most importantly DO NOT OVERTIGHTEN, if you break this sender off in the tranny your in a world of hurt! sorry for shouting but very important.
