Front bumper bolt size question
Old Nov 17, 2006 | 11:08 PM
Deadeye1963's Avatar
Deadeye1963
Smile Front bumper bolt size question
Hello. I usually hang out down at the '61 to '66 truck forum but I just bought a 1977 f150 and need to tow it home.
I will be using a tow bar and I would like to mount the brackets to the front bumper. The bumper is the standard chrome variety and It appears to be mounted to the frame using two bolts (one on either side of the license plate). Can someone tell me if this is correct? I am wanting to use grade 8 bolts in place of the stock bolts and need to know the size of the bolts currently used in the front. Any info. and advice will be greatly appreciated!
Thanks!
Old Nov 18, 2006 | 10:52 AM
Deadeye1963
Smile
I read a posted question on this forum that asked about the front bumper bolt nut size. The nut requires an 11/16" socket or wrench. Going by that bit of info. I come up with a bolt size of 1/2". I want to temporarily replace that bolt with a hardened bolt for towing using a tow bar attached to the front bumper. Can anyone verify if this is the correct size? Thanks!
Old Nov 18, 2006 | 08:32 PM
gbrett's Avatar
gbrett
should be 4 1/2 inch bolts 2 down from top of bumper and 2 in the front of the bumper
Old Nov 19, 2006 | 08:34 PM
GreenMachine'77's Avatar
GreenMachine'77
the bolt number out of the mechanic manual is 383465-s2, it didnt say the size...i dont know if that will help but you may be able to look it up
Old Nov 20, 2006 | 01:05 PM
Alvin in AZ's Avatar
Alvin in AZ
Yeah saw that thread and skipped over looking at yours thinking it was the same one. Sorry it's so late. :/
11/16" nuts usually fit a 7/16" bolt and that's the case with my 75 front bumper bolts.
Alvin in AZ
dennis wagner
Feb 26, 2017 01:03 PM
jerryst
May 29, 2016 08:39 AM
thunderbirdcakes
Sep 12, 2013 05:48 PM
Fordzilla80
Jul 31, 2011 12:19 AM
jonrjen
Sep 1, 2009 08:54 PM
