Timing
Old Nov 17, 2006 | 01:29 PM
maddmaxx29's Avatar
maddmaxx29
Timing
Alright I bought a 79' F-150 with an 80/81 302. So here's the deal, it doesn't run for crap. What is the firing order and the timing supposed to be? I can't seem to get it dialed in and any help would be great.
So here are the symptoms, it idles real lopey and when you accelerate it
backfires and dies or won't come up to speed. Is this the timing or something else?
Old Nov 17, 2006 | 01:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. Check the links at the bottom, and the menu bar at the top, of the page for more information and resources. Have fun!
Old Nov 17, 2006 | 02:50 PM
arctic y block's Avatar
arctic y block
Sounds like vacuum leak to me. Don't remember the firing order at the moment(CRS). Once you eliminate the firing order and or wet or cracked dizzy cap. I would look for open vacuum lines and use a can of brake clean or either if you are outside. Start the engine spray the brake clean, WD40, Either around where the head and intake manifold meet as well as the base of carb. Check the throttle linkage that runs through the carb and holds the throttle plates for up and down or side to side play. If the engine revs while spraying it down you have found a leak. If any play in the throttle ya need to re bush it or replace it. The carb that is.
Old Nov 17, 2006 | 05:18 PM
HemiEater's Avatar
HemiEater
Old Nov 17, 2006 | 05:24 PM
HemiEater's Avatar
HemiEater
Hope this helps.... also check the vacuume at the dizzy, it should be ported (no vacuume at idle)
Old Nov 18, 2006 | 09:40 PM
PierceEye's Avatar
PierceEye
Hemi,
On a 302 w/Edelbrock intake and carb there is a timed port and a full port, the full port is on the right if facing from the front. Which should I be using?
Old Nov 19, 2006 | 12:43 AM
HemiEater's Avatar
HemiEater
Timed port. the one that has no vacuume at idle, check it with your finger with it running.
