2wd Vs. 4wd
Old Nov 17, 2006 | 11:06 AM
scratchedvinyl's Avatar
scratchedvinyl
2wd Vs. 4wd
I'm considering buying an '04 2WD Expy (w/ 5.4). Originally I wanted a 4WD vehicle for NJ winters but I am reconsidering since I might be able to increase fuel economy by saving about 250 lbs. Does anyone have real life experience with any differences in fuel economy between a 2WD and a 4WD? Also, this vehicle does not come w/ optional traction control (just a limited slip axle) - how well (traction, handling, etc.) do the 2WD Expy's do in bad driving conditions?
Thanks much.
Old Nov 17, 2006 | 12:21 PM
shov76's Avatar
shov76
I have an 03 with the option of 2WD, auto 4WD, 4WH High and 4WD low. When I run in 2WD vs auto 4WD the diff is minimal. Maybe 1 MPG.
On the limited slip deal. I have that also (3.73LS). It depends on the tires you have and what the expextations are. If you step on the gas in snow both whells will spin rather than the 1 wheel that usually happens on cars. The back end will come around on you if you're not careful. I know that North Jersey is certainly a place I'd use 4WD in the winter
Old Nov 17, 2006 | 02:05 PM
wrenchturner's Avatar
wrenchturner
eat the mileage. when or if you get stuck fliping the switch is woth it. I fee better knowing my wife can turn a know and make it home easily. I have an 03 FX4. and the four wheel drive system is impressive. My last 4wd was an 81 f150.
Old Nov 17, 2006 | 09:12 PM
aagitch's Avatar
aagitch
Definitely go with 4wd. I personally think 2wd suv's and trucks in the north are a waste. Up in my home state of Iowa, I was able to drive through some snow with my fwd stratus and dad couldn't with his 2wd tundra. Couple years ago I was able to use my expy to drive up a snow and ice covered steep hill, I was very impressed. Wish I could use 4wd more often.
Old Nov 17, 2006 | 10:17 PM
amm888's Avatar
amm888
i've got the 2wd and it works just fine all winter long! perhaps i should mention i live in southern cali...
i've had the 4wd previously, both were 5.4 and i can't say i noticed any difference in MPG.
Old Nov 18, 2006 | 08:30 AM
scratchedvinyl
Thanks for the input. I just bought the 2WD '04 XLT. I understand what your saying about how 4WD is critical in snow but... even in NJ I might have had the opportunity to drive in snow/sleet only a handful of times in the past two years. To me, the added weight and friction of a 4WD transfer case (not to mention there's more mechanics to worry about breaking down) , the money I saved buying a 2WD ($17,500 w/ 30,000 miles) and possibly gaining a mpg highway made buying a 2WD a no brainer. The only bummer is that I can't take it on the beach...
Thanks again.
Old Nov 18, 2006 | 08:46 AM
Expefan's Avatar
Expefan
What you will save in MPG's by not having the extra weight and friction of the front diff & transfer case, you are going to loose in trade-in value when you sell.
Old Nov 18, 2006 | 10:51 AM
04markIII's Avatar
04markIII
Thanks again.
i bought my 03 eddie bauer in september loaded(see sig) 4x4/awd for $15,200. only major thing it needed so far was a rear diff rebuild. ebay has some good deals.
Old Nov 18, 2006 | 10:52 AM
04markIII's Avatar
04markIII
too late as i see you already bought it. enjoy.
Old Nov 18, 2006 | 10:54 AM
amm888's Avatar
amm888
Thanks again.
this is one of the main reasons i avoided the 4wd my second time around (and the fact that i simply didn't need it). my awd system had issues and the 4wd system in general seems to crop up problems quite often, or so it seems by the posts on this site.
not trying to dis 4wd trucks though, 4wd is great when you need it.
enjoy the truck,
al
Old Nov 18, 2006 | 12:38 PM
houlster's Avatar
houlster
Milage difference isn't worth *not* getting 4wd IMO.
Old Nov 18, 2006 | 03:55 PM
aagitch's Avatar
aagitch
You shouldn't have problems with your 4wd system unless things have been neglected. Resale value for 2wd is horrible compared to 4wd.
