headers for my 302
Old Nov 17, 2006 | 12:02 AM
papabills54's Avatar
papabills54
headers for my 302
hey's guy's, I need to redo my exhaust on my 54 ford pu so I thought while im at it I should consider putting headers on it as well . Im wondering if anyone else has close to the some set up as I? I've got a 80's 302 with an AOD transmission. I have also changed the front suspension to a volare with the volare gear box. Is there a set of headers that I could use already made that I could just bolt on? I will have a muffler shop pipe it and would like to run the exhaust below the step in front of the rear wheels. any help would be appreciated. bill
Old Nov 17, 2006 | 06:15 AM
AXracer's Avatar
AXracer
I'd check with Sanderson, they make headers to fit almost any combo, and if they don't have it the'll make it. Whatever ones you buy, be sure to get them ceramic coated either from the manufacturer or aftermarket. well worth it!
Old Nov 17, 2006 | 08:19 AM
joe hoffman's Avatar
joe hoffman
Sanderson block huggers ceramic coated
Old Nov 17, 2006 | 06:19 PM
53fatfndr's Avatar
53fatfndr
I would take some measurements and see how much room you have to work with. I'm willing to bet you can find some blockhugger headers from Hooker or Headman that will work and will cost less.
Old Nov 18, 2006 | 12:38 AM
imlowr2's Avatar
imlowr2
I spent a good amount of time finding headers to fit my 289 in my 56. After trying to install four sets of headers from longs to blockhuggers, I got a set of Sanderson shorties, had em ceramic coated and installed them with no banged up knuckles. Sanderson is the way to go.
Old Nov 20, 2006 | 11:50 AM
55FordLover's Avatar
55FordLover
I used flowtech headers and had 1 problem - had to go with a high torque starter to clear but that was the plan anyway!!!!! 1st Lady didn't mind at all....
